Head Gasket replacement
This is similar to another post about coolant disappearing. I need to know how much is involved in replacing a head gasket on a 2000 Chrysler LHS. I have replaced all the hoses, water pump but not the radiator and completely flushed the system. I did a pressure test and there are no leaks anywhere. I took it to the shop and was told I have a leaking head gasket since it has a rough idle when cold and there are no leaks visible. It takes about 400 miles or so and then I notice that I need to add more coolant.
Is this a job that is better left to a mechanic? Thanks!
