Inner CV Joint trouble
Old Jan 30, 2012 | 07:57 AM
sbrown77's Avatar
Exclamation Inner CV Joint trouble
I have a 99 Concorde LXi and we are replacing the entire right side cv joint axle shaft as well as the control arm. We have gotten the cv axle removed from the hub and the control arm off no problem, but we've hit some random snag. We can't seem to pry the inner cv joint from the transaxle case. We've been using a flat bar to pry it loose and have tried turning it one quarter turns several times to see if the ring on the inside would let loose, but it will not budge. Is there a trick to removing the inner cv joint on this Concorde?
Old Jan 30, 2012 | 09:06 AM
just man handle it bigger pry bar
Old Jan 31, 2012 | 06:58 AM
sbrown77's Avatar
Unhappy Ain't happenin
Seriously spent another 2 hours yesterday trying to get the joint off. The snap ring would not release no matter what we did. We have sprayed with penetrating spray like crazy and it's not doing anything. The joint moves up and down, side to side, and you can pull it out til it catches up on the snap ring. Is there any reason why this snap ring will NOT let loose??
Old Jan 31, 2012 | 08:04 AM
12 years old its been in there awhile
Old Apr 15, 2012 | 07:05 PM
purprotein's Avatar
Hi, how did you finally get the inner joint to release ...I have the same problem with a 99 lhs...tried everything...
Old Apr 16, 2012 | 08:05 AM
sbrown77's Avatar
Ended up having to use a ridiculous amount of leverage!! We just soaked the joint where it joins the transmission with penetrating spray and then attached a rachet strap to one side of a busted car we had next to mine and then attached a chain to the strap and the cv joint. Then we racheted super tight and knocked the joint with a mallot to get it to wiggle loose. It finally came off but it took 3 days and all this awesomeness.
BEAST2011
Jan 19, 2011 07:55 AM
shootme5150
Aug 30, 2010 04:50 AM
kentchris
Jun 24, 2009 06:52 PM
d50erock
Nov 21, 2006 04:10 AM
Vandal_Mav
May 19, 2005 08:06 PM
