LHS Cruise Not Working
Old Aug 21, 2008 | 03:45 PM
thomasw120's Avatar
Default LHS Cruise Not Working
I have a 95 Chrysler and the Cruise has never worked. If you put a scanner on the car it says the servo won't engage. I have replaced the servo with a brand new one from the dealer. The servo also has a good vacuum and the buttons all work according to the scanner. When you drive down the road the cruise light comes on and when you push the set button the scanner will tell you it tries to set but faults out saying the servo won't engage. Any ideas?
Old Aug 22, 2008 | 02:47 PM
moe's Avatar
moe
Default RE: LHS Cruise Not Working
brake pedal out of adjustment?
Old Aug 23, 2008 | 01:41 PM
thomasw120's Avatar
I put this car on a scanner and used a function that tests the value of the brake pedal. When pressed the value is low and when depressed it is high. This according to the scanner indicates that the brake switch is operating correctly. My guess is that a wire in between the servo and the steering wheel has gone bad but I was curious if anyone else might have any other reasons to why the cruise may not work. It has a good vacuum, a brand new servo and all the buttons on the steering wheel operate. Thanks!
carsoftampabay
Cirrus & Breeze
Oct 26, 2012 11:31 PM
ajackielyn
Nov 4, 2010 04:01 PM
cowli4nia1
Mar 28, 2010 06:07 PM
chrisarvor
Apr 17, 2007 10:14 PM
nithawk2000
Mar 27, 2006 11:55 PM
