Obdii plug wiring location
Old Sep 11, 2010 | 04:00 PM
ghardy7605's Avatar
Default Obdii plug wiring location
After pulling codes on my 1999 Chrysler Concorde with a 3.2L engine, I pulled the plug. I got another CEL, went to plug my scanner in, the end of the plug was attached to the scanner and one of the wires had come out of the remainder of the plug. I put it where it looked like it came from, put the plug back together, now am getting a link error.
Can anyone give me a color coded wiring diagragm and the pin location of this vehicle.
Your help would be most appreciative,
Greg
Old Sep 12, 2010 | 12:26 AM
Data link connector - black 16 way cav circuit function
1 - -
2 d25 20vt/yl pci bus
3 - -
4 z1 20bk ground
5 z2 20bk/lg ground
6 d20 20lg sci receive
7 d21 20pk/tn sci transmit
8 f11 20rd/wt fused ignition switch output (st-run-off)
9 - -
10 - -
11 - -
12 - -
13 - -
14 d6 20pk/lb sci receive
15 - -
16 m1 20pk fused b(+)
Old Sep 12, 2010 | 07:14 AM
ghardy7605's Avatar
Thanks,
I will try to get them in the right location now, would you happen to have a picture in case I get confused on wire description? If not, thats ok, just visual sometimes helps me see it better.
Thanks for the help, I do appreciate the knowledge you have,
Greg
Old Sep 12, 2010 | 12:40 PM
ghardy7605's Avatar
Default diagragm
Hi again,
Never mind, after getting some light, I finally saw the numbers on the back of the plug, with these bad eyes of mine did not see that initially.
I got the wires back in the proper pin location, now she works like a champ, evidently the lock on the plug is broken, so I zip tied it together, hopefully, will not have that problem again.
Thanks again for the help, it is greatly appreciated,
Greg
swiftgate
Dec 23, 2014 01:32 PM
Munro
11
Feb 24, 2014 01:13 PM
neilcrd
Apr 30, 2011 03:59 PM
brieanna82
Oct 7, 2010 07:52 PM
davidplans
Sep 25, 2010 08:39 PM
