P1684 an P0601 Chrysler 300M (2001)
Old Feb 24, 2016 | 12:13 PM
Paui's Avatar
Question P1684 an P0601 Chrysler 300M (2001)
Hi!
I have a Chrysler 300M 2.7 automatic (2001). A few days ago the malfunction light (MIL) turned on. Yesterday I did the mistakes test and it showed the errors P1684 and P0601. However, the car run properly. Today, while I was driving the light (MIL) has turned off, but the errors keep continue to appear..
What is this about? Why has the light turned off now? What can I do?:confuso:
Thanks in advance!
Old Feb 24, 2016 | 06:56 PM
FIREM's Avatar
1684 is common on these cars. Battery disconnect in the last 50 starts. Check all battery connections, battery, jump post, and ground on strut tower. Must be clean and tight. I suspect an open in the battery circuit reset the codes and they will come back.
0601 is an Internal ECM failure, no fix other than new engine control module. Some folks have driven for years with 0601 with no issue.
Old Feb 24, 2016 | 09:19 PM
yep only issue is if you have emissions or state inspection
Old Feb 25, 2016 | 02:52 AM
Paui's Avatar
Thank you so much for the information. I have been looking for information about the codes and just like you tell me, p1684 is not important. I worry the code p0601 primarily, because I don't understand entirely its meaning and it appears more worrisome.. I'm going to check and clean all battery connections, after I'll reset codes.
Old Feb 26, 2016 | 11:41 PM
601 is an internal EEPROM failure the computer have a back up chip incase that main one fails.
David S.
Aug 1, 2014 03:48 PM
AdamStrad37G
Mar 19, 2012 06:59 AM
stewartsoftware
Apr 17, 2011 08:58 AM
Burkett1970
Feb 24, 2008 11:40 AM
drw170
Jun 22, 2007 09:11 AM
