Trans Pan bolt Torque
Old Sep 30, 2008 | 02:42 PM
billbon8's Avatar
Default Trans Pan bolt Torque
Hello,
I changed the fluid/filter on my 01 Concorde with 59K miles. I had seen a drip and I think the gasket was leaking. When reinstalling the pan and new cork gasket, my Chilton's book said to torque the bolt to 19 ft-lbs. That seems a bit high to me. I will admit that it did take some torque to initially break the bolts free. Do you folks agree with the 19 ft-lb recommendation? I thought 10 might be more reasonable. Also,the change resulted in about 5.75 quarts being replaced. IfI only put in 4 (like the book recommended) and then added as needed after starting the car, I would have started way too low.
Finally, on a previous post I wrote about an engine oil leak on the drivers side by the alternator. On closer inspection, I think the leak is coming from the fill tube to pan connection. Any thoughts on how to fix this? Based on the engine arrangement, I can't even see this part. I'm not sure if it bolts on...
Thanks,
Bill
Old Sep 30, 2008 | 08:25 PM
Default RE: Trans Pan bolt Torque
use RTV not a gasket they why its leaking.
Old Oct 1, 2008 | 07:57 AM
billbon8's Avatar
What I replaced was factory RTV and it was very difficult to get the pan loose (after 7 years). Two bolts on the drivers side front were slightly loose. I think that's where it was leaking. The cork gasket came with the new filter. I've seen that Chrysler now offers their own rubber reusable gasket (about $30) but I didn't buy it. Anyway, I was wondering about the bolt torque specs. Is 19 ft lbs correct?
taug14
Aug 4, 2012 12:47 PM
tmizzle
Mar 6, 2012 07:17 AM
Qckslvr
Dec 1, 2010 09:00 PM
jetek2588
Sep 5, 2009 04:51 PM
tntandc
Mar 25, 2008 08:38 PM
