02 2.7 Conv starts, stalls imediately
Old Jan 27, 2008 | 01:06 PM
Attitude0917's Avatar
Default 02 2.7 Conv starts, stalls imediately
I have a 02 sebring conv limited with 2.7. It will start, but then stalls right after. Everynow and then will run, but when I shut off... back to the same prob. Also, sometimes it won't even try to engage starter, not even a click. Wait a few, and back to the same story of run then stall. New battery. Also, how do you pull the codes on this car without a reader? I know, I need to go get a book on it. That will be tomorrow. I just aquired this car, so I know nothing of its history. Has 87000. Any insight into this will be greatly appreciated.
Old Jan 30, 2008 | 07:31 AM
WYOCHIMNEYSWEEP's Avatar
Default RE: 02 2.7 Conv starts, stalls imediately
you need a scanner to pull codes. does the check engine light come on before it stalls?
Old Jan 30, 2008 | 05:58 PM
Default RE: 02 2.7 Conv starts, stalls imediately *SOLVED*
I have discovered the craziest thing by chance. There are 2 keys, one factory, and one made by chrysler later. The factory key will start the car and run all day long. The "later" key will start it, but stall immediately. Apparently, it thinks it is being stolen, and shuts down. I guess I will just use the factory key.
Thanks for the insight!
Old Jan 30, 2008 | 08:12 PM
there you go found the problem. antitheft module cool
Old Feb 2, 2008 | 09:45 PM
bandaide's Avatar
Attitude,
I'd suggest you bite the bullet and get a second copy of the OEM type key. There is an RFID chip in the head that works with the on-board electronics to help you keep your car. It's a lot less expensive and confusing to get the key now instead of after you've lost that one.
The system is called Sentry Key BTW.
dmoore
Apr 5, 2014 11:51 PM
dmoore
Nov 4, 2013 05:06 PM
Titusflumpo
Jun 21, 2011 04:09 PM
tmerila
Aug 28, 2009 02:45 AM
TCIDAD
Nov 12, 2008 11:52 AM
