02 Engine Swap
Old Nov 20, 2022 | 02:40 PM
Mel63's Avatar
Default 02 Engine Swap
Can I replace an 02 Engine with an 07 engine?
Does the engine need to have the same 8th digit/letter as the original did?
Just want my kids car fixed so I can have my car back.
Old Nov 21, 2022 | 06:50 AM
FIREM's Avatar
While I do not know the direct answer to your question, be sure to research thoroughly before moving forward. I know for a fact to LH series cars have some quirks. Example 99-01 need to swap Flywheels and cam drives to work in 02-04.
Around 2004-5 Chrysler significantly changed computer control systems making pre and post incompatible with out mechanical changes also needed.
Good luck.
https://www.chryslerforum.com/forum/...ne-swap-34024/
https://www.chryslerforum.com/forum/...ne-swap-34240/
Old Nov 21, 2022 | 10:37 AM
There was a significant change in the electronic engine control system halfway through the 2004 model year. If you know exactly what you're doing you might be able to make that swap work. If you're looking for a plug-and-play swap, get an engine from the same model year.
andruvision
May 2, 2022 07:53 PM
Randall Caldwell
Apr 30, 2020 08:32 PM
meahsdaddy
11
Jul 10, 2017 12:53 PM
meahsdaddy
Jun 11, 2017 08:11 AM
scottzeuroamerican
Feb 16, 2010 10:18 PM
