02 Engine Swap
While I do not know the direct answer to your question, be sure to research thoroughly before moving forward. I know for a fact to LH series cars have some quirks. Example 99-01 need to swap Flywheels and cam drives to work in 02-04.
Around 2004-5 Chrysler significantly changed computer control systems making pre and post incompatible with out mechanical changes also needed.
Good luck.
https://www.chryslerforum.com/forum/...ne-swap-34024/
https://www.chryslerforum.com/forum/...ne-swap-34240/
Good luck.
There was a significant change in the electronic engine control system halfway through the 2004 model year. If you know exactly what you're doing you might be able to make that swap work. If you're looking for a plug-and-play swap, get an engine from the same model year.
