03 dash control unit
Old 07-30-2009, 08:51 AM
markseb03's Avatar
Default 03 dash control unit
On my 03 sebring LX, with the ac system on recirc, most of time it will blow through the defrost. It looks like the control unit in the dash is bad from what I have read and the fact I can press on it near the selector switch and it will change where it blows (sometimes vents, sometimes floor vents). What I am wondering is if when I replace it, can I purchase the unit with auto temp control (looks like the internal temp sensor is on the unit itself) or do I have to get the manual standard one.
Dash control unit, all models, sedan, w/atc
2003
or
Dash control unit, all models, sedan, w/o atc
01-06
Old 07-30-2009, 10:04 AM
The automatic temp control requires a sunlight sensor on the dash and a body control module (computer) that is set up for it. Your car doesn't have those things.
Before you replace the control head, take a look at where the smaller plug ataches. There are 8 prongs in that socket. If any are loose, take the unit apart and carefully solder them. That might cure the problem.
Old 07-30-2009, 12:58 PM
aliasJohnQ's Avatar
Default Sensor for dash lights
Could anyone tell me how to fix my dashlights, which are going on and off without touching them?
Thanks!!!
marty1966
04-02-2018 04:32 PM
Huggy59
10-17-2011 06:23 AM
stoneyh1
10-07-2011 09:34 AM
alan
11-19-2008 01:22 PM
plank01LXI
01-25-2006 02:18 AM
Quick Reply: 03 dash control unit
