04 Sebring 2.7 flex fuel swap to non flex fuel
Old Mar 13, 2012 | 06:17 PM
MaxFlow's Avatar
Default 04 Sebring 2.7 flex fuel swap to non flex fuel
Have an 04 Sebring 4dr that blew up *rod bearing* and I sourced another engine from another 04 Sebring. The other engine was flex fuel and the original one wasn't. Well long story short I had to change the flywheel to get it to run. It runs but won't accelerate cause the cam sensor isn't seeing signal. Can I just change the tone ring from the original engine like I did the flywheel and get this thing to run properly or is there a ton of other things that need to be done.
This is my first post here although I have read the resources many times before to help me fix things. Thanks for all the help.
Old Mar 13, 2012 | 07:29 PM
TNtech's Avatar
YES, you can just change the cam sprocket with the tone wheel made on it. It wasn't a matter of it being FFV/Non FFV, it was PCM type NGC/Non NGC. It's seeing the cam signal, it's just limping you because it sees the signal so scattered. I advise getting a new primary tensioner and inspecting the chain guides while you're in there. 2004 was the last year they used both types.
Old Mar 19, 2012 | 01:18 AM
MaxFlow's Avatar
Thanks a ton. I'll get to work on it and get back and post results. I was just afraid everything would be haywire since it was FFV.
Old Mar 19, 2012 | 06:21 PM
AnthemBassMan's Avatar
From: T-County, Ohio. Good ol' farm country! Or at least what's left of it...
-Basically just don't run E85 fuel in it and you should be fine...
L8R,
Matt
Old Apr 15, 2012 | 10:56 PM
MaxFlow's Avatar
I'm finding problems getting the correct tone ring. I have pictures of several different ones and the S860 which is what I thought I needed looks to be the same as in the car at present. The engine didn't come from a Sebring as the Junkyard guy said, it came from a 04 Stratus.
Here are the tone rings I've found:
I have ordered the SBEC cam gear and it seems like its the right one on this image. I can't find the left one and I think that's the one I need.
This is another one I found on the internet.
http://i890.photobucket.com/albums/a...etnewstyle.jpg
Just a pick of a different one I found on the internet
http://i890.photobucket.com/albums/a...effpulley2.jpg
This is the cam gear that I ordered that is suppose to be the right one but it is the same one that is in the car now.
esanhusky
Mar 12, 2012 05:07 PM
04_sebring
Nov 21, 2011 10:48 PM
tiffanys4
Sep 22, 2010 07:28 PM
jcl_cls01
Aug 3, 2009 04:05 PM
Apr 28, 2006 05:53 PM
