04 Sebring rabbit hole
Old Nov 6, 2018 | 09:51 PM
Ralph s's Avatar
Default 04 Sebring rabbit hole
trying to help a friend with his 04 Sebring convertible 2.7. He has had it many places and replaced loads of parts. 1st it blew the #4 plug. Hole was tapped new plugs, #4 coil and injector replaced. New valve cover and intake gaskets. After that car died randomly throwing cam and Crank sensor codes so both were replaced. Then when the car was warm turned on defrost to have the car would die. The car would also die when coming to a stop. No fault codes. Battery and alternator were replaced. Car now does not die but when stopping, holding windo switches to long, or heavy load the engine bogs down.
Old Dec 3, 2018 | 08:45 PM
2004SebringSedan2.4L's Avatar
Hows the voltage? You should be getting 12 volts. Anything less and you'll have problems with who knows what.
Old Dec 4, 2018 | 10:51 AM
The car stalls when defroster turned on (The A/C kicks in when defroster is turned on) or when an excessive electrical load is called for. Sounds like the car won't idle properly when some additional load is placed on the engine at idle. That is supposed to be taken care of by the computer acting through the idle air control, which should kick up the idle a little when there's an extra load. Check the Idle Air Control.
Old Dec 4, 2018 | 01:24 PM
Id have the alternator tested, I had to take it out for an accurate reading. It was bad and had to be replaced. Car runs great now.
Old Jan 4, 2019 | 09:54 AM
nauman_mustafa's Avatar
Is the Serbing a good all around dependable and long lasting vehicles?
Old May 10, 2019 | 09:33 PM
If maintained well yes, if not then no. I bought mine knowing how much it would be to fix the issues and it worked out. Any good car will run like crap if the previous owner didnt maintain it right.
annies
May 4, 2015 08:33 AM
godsall84
18
Aug 13, 2013 06:34 AM
curt_wells@earthlink.net
Jul 29, 2011 09:00 AM
5thvet
12
May 21, 2010 08:54 PM
Johnja
Nov 4, 2007 04:53 PM
