1997 sebring2.5 boug down change every thing emergency need tech help
Old Sep 7, 2008 | 11:53 PM
jaydub54's Avatar
Default 1997 sebring2.5 boug down change every thing emergency need tech help
new, seen forms and they were helpfull my problem is that ive change fuel pump distrib,spark plugs' wires, ecm/cpu and it still wont run codes odb2 said basic is throttle control and idle control is malfunction or its have low voltage input codes po122 po123 and some others read when engine is off erase still there , idle pos sen never stop me before why now?still working on it but its no doig the trick ive even change o2 sen nothing i unplug idle pos sen and it starts ony in idle. press gass boggs down runs sh tty plug sen back up it stops running i lost the paper with the codes and vin so if some can help me now shoot please need it had car for a week money is geeting low also if tech can email me so ican get this resolved quick thanx, jdub
Old Sep 8, 2008 | 09:13 AM
Default RE: 1997 sebring2.5 boug down change every thing emergency need tech help
P0122 = Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 = Throttle/Pedal Position Sensor/Switch A CircuitHigh Input
Sounds like these are contradictory codes getting both high and low input from the throttle position sensor. Check the circuit for that sensor for shorts to battery and/or ground. By the way, it's very difficult to understand what you are trying to say with your post. Try reading it back to yourself after writing it before posting it up and you might be able to clarify it somewhat so people can understand what you are asking.
sebringing
Dec 17, 2014 03:45 PM
faneuffm06
Jun 8, 2011 09:14 AM
ChryslerNamedTrixie
Aug 21, 2005 05:58 PM
redriderbob
Dec 11, 2004 05:11 AM
