1999 Sebring JXI stalls while driving and while idling
Old Nov 17, 2018 | 12:12 PM
hippiestokes's Avatar
Default 1999 Sebring JXI stalls while driving and while idling
My 1999 Sebring JXI convertible stalls while it's idle and while I'm driving it. It is at a mechanic and has been there for a month now. They can't figure out what's wrong with it. The Sparks plugs, spark plug wires, distributor, crankshaft position sensor, timing belt and water pump have all been replaced. The egr valve, the flywheel, map sensor, have been checked and are good. Any vacuum leaks have been fixed. When it stalls it refuses to start back up unless it has been sitting for a while. When I tried to start it after a stall it would crank and crank and crank but not turn over and start. The mechanics don't wanna give up on it but they can't figure out what's wrong with it. They said they've been on multiple forums with no luck. Any ideas what could be wrong with it?
Old Nov 18, 2018 | 09:48 AM
HemiHarza's Avatar
Hi there hippiestokes,
I have 1996 JXi convertible and had the same issue. Problem in my car was the ASR ( Auto Shut Down relay) and DTC test gave me the error of communication between engine control and gearbox control.
Both issues were fixed by replacing the ASR relay. Located in the relay box in the engine compartment and cost only 7 Euros. No issues after that
I suppose that the mechs have check this ??
Old Dec 28, 2018 | 01:30 PM
bboma's Avatar
You need to find a mechanic that knows what he is doing instead of a parts changer.
Old Jan 9, 2019 | 09:14 AM
nauman_mustafa's Avatar
Hi, from where i can get a good mechanic to replace parts item as it's urgent to re-place.
please advice me from your end guyz and thanks a lot in advance.
Old Jan 9, 2019 | 09:30 AM
REBEL59's Avatar
IF you would tell what vehicle exactly you have and WHERE on planet EARTH you are located, maybe a member here that MIGHT live near you could help you with that request!
Wolf359
Nov 7, 2017 12:04 PM
AIRaquarian
Dec 2, 2012 09:32 PM
Ms.Scarlet
Apr 24, 2012 07:39 PM
PowerAuthority
Oct 13, 2009 05:49 AM
LisaG
Aug 27, 2009 09:14 AM
