2.7 Engine failure
Old Jul 29, 2008 | 07:24 PM
k7t266a's Avatar
Default 2.7 Engine failure
Will a 1999 3.2 work in a 2001 Sebring? Do the exhaust manifoldsexchange? What about the intakes? Im not thrilled about putting in another 2.7 so any info would be great.
Old Aug 3, 2008 | 11:23 AM
cstingray's Avatar
Default RE: 2.7 Engine failure
Hey bud how are you?
I'm the owner of a 1999 chrysler Sebring Conv. i believe the engine you're referring to might be the 2.5L V6 6G73 Motor, in which case i'm going to say it most likely may not fit your model year for 2reasons, electrical and electronic plugs might not be interchangable, and mounts might not be in the right place, as it its my understanding one was made by Mitsubishi (2.5L), and the 2.7L was a chrysler design. Lastly i'm not a mechanic, but i'm into these cars and done some research, may i suggest you give the Mitsubishi 3.0L V6 motor a look, it did come with the Sebring coupe, and sedan from 2001 onwards to the best of my knowledge, and i believe if you can come across the motor in the MITSU ECLIPSE GTS it should have an addition 10HP, alas 210HP, hope this helps
Adam
1999 CHRYSLER SEBRING LIMITED CONV.
2.5L V6 6G73 / Autostick
Old Aug 3, 2008 | 08:50 PM
k7t266a's Avatar
Thanks for the info. I may just go with the 2002 instead of 2001, I heard they fixed some issues that year. Is the electrical the same or is ome of that differnt to. I know the intake on the 01 has a heat pipe running to it but the 2002 does not.
Mohsen Dehghan
Cirrus & Breeze
Nov 30, 2014 10:05 AM
2001Sebringconv
Nov 7, 2014 03:27 PM
Duudinja
Apr 18, 2013 02:27 AM
marinewife
Jul 22, 2010 10:26 AM
adsebring
Jun 20, 2008 08:25 AM
