2004 Chrysler Seabring no bus message
Old Jan 25, 2018 | 08:23 PM
Michael White's Avatar
Angry 2004 Chrysler Seabring no bus message
I recieved a no bus message on my Chrysler seabring v6. I replased the crankshaft position sensor and I am still recieving the message
Old Jan 26, 2018 | 10:59 AM
"No Bus" means that the network that connects the car's computers to each other and to the things they monitor and control is not working properly. Changing the crankshaft position sensor is like changing a light bulb when there's a power failure in the neighborhood...it ain't gonna help.
This is not really a DIY issue. You're going to need some professional help.
Old Jan 26, 2018 | 05:38 PM
flaokie's Avatar
Worth a try – disconnect the battery for 10 minutes.
You can also pull the computers plugs check that all the connectors are clean, and reconnect.
Also make sure you have a good charged battery.
If it turns out to be a bad computer(s), there are companies that sell refurbrushed units programmed specifically for your car.
samanthahotmess
Jun 9, 2014 02:26 PM
jgraham
May 4, 2011 11:03 AM
estein01
Mar 29, 2011 09:47 PM
jasonu76
Apr 20, 2010 02:10 PM
dphickster
May 5, 2008 09:00 PM
