2004 Sebring LX - Weird P0432
Old Aug 23, 2017 | 07:36 AM
Michael Dugas's Avatar
Default 2004 Sebring LX - Weird P0432
Okk so a family member has passed on an 04 Sebring LX to me. When the car is in any ignition position other than run there is no CEL. Plugin Launchtech X431 and it will get no codes. Start the car and the CEL comes on. Using launchtech X431 I am able to see P0432, but I cannot clear the code, probably because it does not seem to be storing it.
So now I am debating if I should be replacing Catalytic or if there is possibly an ECU issue because it is not storing the code
Old Aug 26, 2017 | 10:42 AM
I'm now also noticing a knock in engine. Mostly up top. Both fuel trims are -12 and scan tool says ignition timing is 11+ btdc.
Old Aug 26, 2017 | 11:21 AM
REBEL59's Avatar
What motor is under the hood, Check for even a small exhaust leak, particularly around the area before the O2 downstream sensor(flex coupling in the exhaust pipe). IF motor has a EGR valve ..check for pinhole leaks in it's piping.
Old Aug 26, 2017 | 11:02 PM
The dreaded 2.7L.... so I'm assuming the knocking sound I'm hearing is either a stuck valve or timing chain slap. And inturn this could result in coolant hitting O2s which would almost instantly kill them.
WrenchWench
Aug 15, 2014 11:20 AM
tylersheehy
Nov 26, 2013 01:14 AM
jmarotto
Nov 15, 2007 05:57 PM
andypandy22a
Mar 6, 2006 10:43 PM
bryancollier
Nov 2, 2005 05:47 PM
