2007 Sebring Crank but won't start
Old Dec 22, 2020 | 03:11 PM
SUP3RBAMF's Avatar
Question 2007 Sebring Crank but won't start
I have a 2007 Sebring Touring 2.4 cylinder engine that will crank but won't start. Here is the list of things I've already tested and/or fixed on the car.
  • New Electronic Throttle Body
  • New Crank Shaft Sensor
  • New TIPM fuse box replacement
  • New Spark plugs
  • Fuel pump was tested (meaning i turned the key and heard the FP turn on)
  • Battery was tested and working (2 years old)
  • New ECU was replaced (I returned the new ECU once I knew the car was still not starting even with the new ECU)
These are the error codes that I'm receiving:
  • P0652 - PCM Low Voltage
  • P0883 - Power relay for the ECU or TCM has failed
  • P0700 - Tranmission Control system malfunction
  • P0032 - Ho2S sensor
  • U1412 - Voltage condition on injector circuit
However, I was thinking that this is an electrical problem and that either one of my relays was bad (but i just installed a whole new TIPM) or that there is a ground that is loose. Actually, I just though of this while I was typing this up, I never check the actual battery connections and you're probably wondering why, well the battery on the '07 Sebring is located under the drivers side front wheel well. I will be checking this first thing after work tonight.
Any and all help is much appreciated.
Old Dec 23, 2020 | 01:58 PM
Marcelvg's Avatar
the new ecu must this not reprogrammed with the ecu of the automatic transmission and keys?
Old Dec 25, 2020 | 04:32 PM
SUP3RBAMF's Avatar
the new ECU was programmed to my specific Vin number
Old Dec 26, 2020 | 09:25 AM
ggoose's Avatar
Time to stop firing the parts cannon.
Is there spark at the plugs? Spray some starting fluid into the intake and crank the motor. If there is spark, the motor will fire but not run. If there is fire, it points to a fuel problem; no fire points to electrical.
From the codes you show, there does seem to be an electrical issue. What is the condition of the battery and its connections, understanding it is 2 years old? It is not common, but batteries have been know to fail after 2 years. Any corrosion at the battery terminals or at the connection points under the hood will cause a low voltage condition especially when cranking the motor. Low voltage means no fire at the plugs. Yes, to get to the the battery is a bit of a PITA, but it does need to be checked.
A decent odb2 reader/scanner will allow you to monitor the system voltage. Should be 12.2 to 12.4 with the key on. The voltage will drop to around 10.5 volts when cranking the motor. Under 12 volts with or under 10 volts while cranking indicates a problem with the battery or its connections.
Old Jan 15, 2021 | 05:01 PM
Paul Gonsiewski's Avatar
Default 2007 Sebring 2.4 L won’t start. Can’t find the Throttle Position Sensor.
Can’t find the Throttle Position Sensor to change it.
Old Jan 16, 2021 | 06:22 AM
Marcelvg's Avatar
crankshaft sensor?
Old Apr 22, 2021 | 01:03 AM
flamaui's Avatar
Hi, I'm having the same problem with my car 2004 Sebring convertible .
Just wondering if you get your car fixed and what was the problem.
Thank You
Old May 31, 2024 | 05:18 AM
Rylin Drayden's Avatar
Default 2007 Chrysler Sebring · Sedan 4D
I'm thinking of buying a 07 Sebring but would like some advice on if it would be a good buy. I seen a post on Facebook about a 2007 Chrysler Sebring that is being put up for the sale but the sellers posted that the car shut off going down the road and won't start again but it does turn over but just won't start. So my first question is would it be worth it to buy the vehicle and secondly what would be the main cause for it to shut off while driving down the highway?
TLT
May 23, 2017 03:13 AM
TLT
May 21, 2017 01:48 PM
steviec2000
Mar 16, 2016 09:39 AM
Sebring_girl_07
Jan 4, 2014 11:21 AM
zubaroo
Jun 26, 2012 07:02 PM
