2012 Chrysler 200 trailer arm
Old Oct 5, 2018 | 06:00 PM
Jrberry13's Avatar
Default 2012 Chrysler 200 trailer arm
I’m trying to replace the rear driver side trailing arm. I’ve got all the bolts off but do not know how to get the cable that runs through it off. I believe it’s the e-break. Any ideas. Thanks
J
Old Oct 5, 2018 | 06:52 PM
REBEL59's Avatar
Yes that is the E-brake cable. It has to be disconnected from the parking brake actuating arm and the cable sheath disconnected from its mounting point at the backing plate. Then you can bring the cable thru the hole in the trailing arm. YUP, there is some brake work involved in changing the trailing arm.
Old Oct 5, 2018 | 07:23 PM
Jrberry13's Avatar
Thank you sir. Not quite sure why they thought that was a good idea. Lol
Old Oct 5, 2018 | 08:55 PM
Jrberry13's Avatar
Where is the parking brake actuating arm??🧐
Old Oct 6, 2018 | 05:34 AM
REBEL59's Avatar
Just woke up and NO MORNING COFFEE YET!!
depending on whether you have drum or disc rear brakes, the drum or rotor must be removed and the shoes probably have to be removed to have working room to unhook the cable eyelet end from the arm and work on releasing the clip that locks the cable to the backing plate. If you're in a high rust area region, have lots of penetrating oil handy , good luck!
Old Oct 6, 2018 | 07:08 AM
Jrberry13's Avatar
It’s has disc breaks.
Old Oct 6, 2018 | 09:11 AM
REBEL59's Avatar
You'll have to remove the rear caliper and take the rotor off, parking brake system is inside the "hat" of the rotor. It is set up much the same as a drum brake system..just no wheel cylinder.
YUP, a bit of work to do!
Old Oct 22, 2018 | 01:03 AM
nauman_mustafa's Avatar
Hi All,
Greetings!
Hope you are doing well. please advice on how i can re-place on rear driver? if anyone have proper knowledge on that please suggest me. waiting for your kind co-operation.
Old Oct 23, 2018 | 09:21 AM
SpaceMonkeyMafia
Nov 20, 2019 09:06 AM
JJarbeck
Jul 29, 2018 11:31 PM
Davey82
Jul 11, 2018 12:59 AM
nitro_warrior
21
Jul 17, 2015 09:37 AM
patchewski
Jun 14, 2010 11:27 AM
