96 sebring jx 2.5L timing belt skip
Old Sep 3, 2009 | 01:01 PM
exigaro's Avatar
Cool 96 sebring jx 2.5L timing belt skip
Hey guys! i found out my timing belt skip like 4 teeth and replace it i made sure to lign all timing marks on both cam/crackshafts and made sure to put #1 at TDC and it wont start, i know that crankchaft rotates 2 times and camshaft only once ratio, i just dont know if i am on the right rataion on the crankshaft of if i am one revolution off. when i rotate it one more the #1 piston it goes to TDC, so could that be the problem and i could be one crankshaft rotation off, what do you guys think? thanks
Old Sep 3, 2009 | 07:59 PM
That engine has a distributor driven off the camshaft, if I'm not mistaken, so the spark timing is controlled by the camshaft position, not the crankshaft position. Was it running properly before you took it apart?
evigilu
Nov 6, 2014 01:54 PM
Imprl59
May 1, 2012 06:49 PM
blurry
Jul 17, 2011 07:53 AM
z131
Feb 27, 2011 06:54 PM
septicman
Mar 21, 2010 08:25 PM
