'99 Sebring won't turn over
Old Dec 13, 2007 | 08:45 AM
jackandh2o's Avatar
Default '99 Sebring won't turn over
Car ran fine, put it in the garage and next morning nothing. Lights work, horn works but not even a click from the solenoid. Battery was 3+ years old so replaced it. Still nothing.
Maybe some kind of safety switch??
Any and all info would be appreciated.
Ray
Old Dec 14, 2007 | 10:16 AM
jdl's Avatar
jdl
Default RE: '99 Sebring won't turn over
Do you have a theft system? Did you try starting it in neutral?I usually go to the starter relay to check the starter circuit. The relay should be in the power distribution center, there should be a diagram on the relay, the terminals may be numbered. If that is a bosch type relay, the terminals should be numbered, the 30 and 87 terminals are for the switch side of the relay, if you use a fused jumper between those socket terminals, the starter should run. If you try this, make sure the tranny is in park or neutral and the e-brake is set. It wouldn't hurt to have a helper setting in the driver seat, with their foot on the brake.
Old Dec 15, 2007 | 10:17 AM
jackandh2o's Avatar
jdl, thanks for the input. We will try this today.
Ray
integlspwr
May 9, 2012 12:30 AM
hesse2115
Dec 10, 2011 05:28 AM
taz
Dec 15, 2010 09:42 AM
edyspunstr
Jun 30, 2008 07:15 PM
gordonblackler
Jan 8, 2007 09:07 PM
