Air conditioner drains
Old May 19, 2014 | 01:58 PM
Wausau 911's Avatar
Default Air conditioner drains
My sons car leaks water into the foot wells when the a/c is on. Probably a disconnected hose or two, but I can't seem to locate them. All help is appreciated. Thx
Old May 19, 2014 | 01:59 PM
Wausau 911's Avatar
Forgot to say its a 2008 4 door sedan, 6 cylinder.
Old May 19, 2014 | 04:14 PM
Probably a plugged drain. It happens when small leaves and such crud from trees fall into the cowl openings in front of the windshield. Look at the steel firewall behind the engine, and look for a rubber tube that comes out, turns down and connects to nothing. That's the drain. Try massaging it to crush the crud in there and with any luck, the stuff should fall out the end. The end is usually flattened but if you squeeze it, it will open and the stuff will fall out.
Bible Believer
Sep 11, 2009 09:34 PM
moorek
Aug 23, 2009 07:29 PM
dynamiteplaya3
Apr 19, 2009 08:28 PM
two30turtle
Jun 19, 2008 09:09 AM
bigrobot
Jun 26, 2007 09:44 AM
