camshaft position sensor getting oil on it
Old Jul 3, 2019 | 12:32 PM
nwmo's Avatar
Default camshaft position sensor getting oil on it
Hey all,
My son's 04' Sebring with 2.4 DOHC engine is leaking past the rear camshaft (seal) presumably and then throws codes due to the oil getting on the camshaft position sensor. Wipe the oil off with a rag, put it back on, and away you go for a few more weeks. Sealed it once with RTV to make sure no oil is getting from the outside/in and it still faulted. I am reasonably certain the oil is coming past the camshaft and the videos I've watched don't show a seal or anything in that location (only in the front).
What keeps the oil from infiltrating the camshaft position sensor? and how can it be repaired/replaced?
TIA,
Chris
Old Aug 5, 2019 | 12:20 PM
boatmoter's Avatar
Talking oil leak
if oil is getting past the cam sensor it has to missing it's Oring or it's loose or defective , make sure it's not a leaking valve cover gasket,if gasket is good, remove cam sensor,clean and inspect for cracks
kythri
Aug 19, 2017 10:53 AM
Cargal
Jan 6, 2015 01:50 AM
Mrbrucie22
Dec 15, 2014 08:16 PM
James Scarlott
Sep 21, 2012 11:29 PM
dcm1971
Oct 13, 2008 12:10 PM
