CHECK ENGINE LIGHT
Old Jun 4, 2007 | 09:40 PM
DAN's Avatar
DAN
Default CHECK ENGINE LIGHT
I tried to get my 99 chrysler sebring smogged. It didn't pass because of my check engine light. The error codes i received were P0174 system too lean(bank 2), P0155 o2 sensor heater fault(bank 2 sensor 1) and P0151 o2 sensor low voltae(bank 2 sensor 1) I changed the upstream oxygen sensor on the manifold, but 5 days later the check engine light came back on. Any advice on where to go next. bank 2 and sensor 1 is referrence to what?
Old Jun 5, 2007 | 04:01 PM
Default RE: CHECK ENGINE LIGHT
what is the new code same one or different?
oh btw what engine and hard top or convertable
Old Jun 6, 2007 | 08:57 PM
DAN's Avatar
DAN
I didn't give enough information, sorry about that.Hard top, v6 2.5 liter engine
Old Jun 6, 2007 | 11:30 PM
what is the new check engine light code?
Old Jun 9, 2007 | 10:12 AM
DAN's Avatar
DAN
P0174 SYSTEM TOO LEAN IS STILL PRESENT AFTER CHANGING THE OXYGEN SENSOR
Old Jun 9, 2007 | 10:31 AM
that means the computer it taking away more then 30% of fuel for longer then the time required. With that info u can have several different tings that will tell the computer to do that. This will be for skilled people so if u dont want to get into this I understand here are a few of the things that can make it go that direction. o2,coolant temp sensor, high fuel pressure,
ENGINE VACUUM - must be at least 13 inches in neutral
ENGINE VALVE TIMING - must be within specifications
ENGINE COMPRESSION - must be within specifications
ENGINE EXHAUST SYSTEM - must be free of any restrictions
ENGINE PCV SYSTEM - must flow freely
ENGINE DRIVE SPROCKETS - must be properly positioned
TORQUE CONVERTER STALL SPEED - must be within specifications
POWER BRAKE BOOSTER - no internal vacuum leaks
FUEL - must be free of contamination
FUEL INJECTOR - plugged or restricted injector; control wire not connected to
correct injector
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
cacarrollsr
Cirrus & Breeze
Nov 11, 2006 10:47 PM
teresadogg
Nov 2, 2005 03:21 PM
ChryslerNamedTrixie
Oct 20, 2005 03:06 PM
