Delayed start issue - 2007 Chrysler Sebring 2.4l
Old Apr 10, 2022 | 09:22 AM
SmallCityDave's Avatar
Default Delayed start issue - 2007 Chrysler Sebring 2.4l
Recently the car has an issue where I turn the key and nothing happens for a second or two then it starts, no crank no effort to try and start then it starts fine the problem seems to be getting worse.
Any ideas what's going on?
Old Apr 14, 2022 | 10:08 AM
ggoose's Avatar
What is the age and condition of the battery? Quick test, the battery voltage ( engine not running for at least 20 minutes) should be above 12 volts, 12.4+ is preferred. A weak/failing battery will cause a low voltage condition and the tipm may not immediately see enough battery voltage to kick the starter.
Old Apr 14, 2022 | 02:17 PM
I thought the same thing, battery is at 12.5v and when it does start turning over it doesn't "feel" weak.
I have not looked at the battery, it seems to be a production getting to it.
Old May 31, 2022 | 05:47 AM
kites0935296661's Avatar
The same problem as you lasted for more than a year, sometimes up and down, and finally there was no response at all. The repair shop found that the anti-theft control module was faulty. Replace the problem and completely solve the problem. Hope it helps you.
Old May 31, 2022 | 07:31 AM
That's great to hear, is it as simple as plug and play or did it need to be programed? I'm think about buying a used one on ebay.
My problem seems to have resolved itself, it must be at least a month sine it's acted up.
Old May 31, 2022 | 06:27 PM
needs to be new used ones have the vin and pin burnt into the module not erasable
Old Jun 3, 2022 | 02:05 AM
It seems that you can't buy second-hand used ones, you need a new one, you need to reprogram and match the keys
Old Jun 3, 2022 | 02:02 PM
Kites, how much did it cost to have that issue resolved?
Thank you both!
chopbangskrew
Nov 12, 2017 10:26 PM
Keith Studley
Oct 5, 2017 07:08 PM
Sebring_girl_07
Jan 4, 2014 11:21 AM
georgedvf
Dec 29, 2010 02:31 PM
Jun 21, 2006 11:09 PM
