Drivers door is not fully closed
Old Feb 18, 2013 | 11:21 AM
unclesam's Avatar
Default Drivers door is not fully closed
Hi.
Just bought 2005 Sebring.
Noticed one problem.
When I close the door it seems that its not fully closed, compared to rear door.
My guess it might be lock?
Any suggestions?
Thanks a lot.
Old Feb 19, 2013 | 10:24 AM
Could be the latch not working properly or the striker needing adjustment. Could be a sign of poorly repaired collision damage. You should be able to check the operation of the latch mechanism using a screwdriver to simulate engagement with the striker plate. If the latch is woking properly, look for proper adjustment.
Old Feb 20, 2013 | 03:51 AM
unclesam's Avatar
Thanks for the answer. Latch seems to be working fine. Maybe I can move striker inwards. Have to check that.
Old Feb 20, 2013 | 11:32 PM
unclesam's Avatar
Moved striker bit inwards, seems to do the trick. Thanks.
nut430
Jul 16, 2014 02:43 AM
DeesSebring
Feb 11, 2010 02:06 PM
xfire04
May 20, 2009 06:32 PM
akide
Mar 21, 2007 07:35 PM
webbch
Jan 4, 2007 09:11 PM
