Fuel Line replacement 96 Sebring JX conv
Old Jun 17, 2007 | 08:26 AM
sumncguy's Avatar
Default Fuel Line replacement 96 Sebring JX conv
Ok brakes lines are just about done. Need to get the last wheel done, then have a mechanic come over pressure test and bleed.
Im trying to get as much info on the fuel lines as I can. The questions I have is / are :
1. Is the only reason to depressurize the fuel system is so that gas wont be spraying all over the place. What damage can I do, if any, if I dont depressurize ?
2. Is a fuel line routing diagram available ? Chiltons dont show one and neither does eautorepair.net. I can trace them, but up toward the engine they disappear into Neverland. The two fuel lines run in parallel with the rear brake lines. Problem is, I dont know which is supply and which is return and how the fuel line is mated to connection points (flaring etc ??)
3. Can I get to the lines by taking the rear seat out ? The book mentions that access is possible with the 98, but doesnt mention any other year.
Thanks in advance for the replies.
Old Jun 17, 2007 | 01:25 PM
Default RE: Fuel Line replacement 96 Sebring JX conv
well if u are replacing the lines u wont have an option but to do so its only 55 psi of pressure u will spray some in your eyes just use common sence put a rag over where ever u start to disconnect the line.
No diagram either haft to manualy route it take a pic of where tehy are now and make them.
I think that is 98 only as well haft to look and see.
Old Jun 17, 2007 | 01:53 PM
sumncguy's Avatar
Thanks, alot Chryslertech ..
How bout the connection points ? Are they flared ... 45 inverted ?
Also I found this on our sister site dodgeforums.com... also own a 06 Mega Cab ..
De-pressurizing the fuel system
1. First you must de-pressurize the fuel system, so you ask how the in the heck do I do that??
-Now as well all know gas is real combustable so safty first absolutlyNO SMOKING of any kind while doing this.
-Remove the rear seat cushion and look for the metal plate it's on the drivers side. It should have 4 small screws holding it in place. Unscrew those and gently raise the cover.
-Now your looking at the top of your fuel pump. Look for the wire clip, and unplug it.
The other cover is the fuel level sender ( in the middle)
-Start the engine and allow it to run until it stops. It should only take a second. Crank the engine 1 more time to ensure that all pressure is relieved.
- Now disconnect the negative battery terminal before doing anymore work.
Will this do for depressurization ?
cirrus98
Mar 3, 2015 11:40 PM
gdwrnch29
Cirrus & Breeze
Apr 18, 2011 06:32 PM
aifam55
Jan 22, 2011 05:49 PM
petewxm
Jul 21, 2010 07:57 AM
