Fuel pump '07 2.4
Old Oct 23, 2010 | 11:03 AM
Oops, sorry about that comment about the coupe, I was thinking yours was an '05.
Cranking should not affect the fuel pump wiring. The fuel pump is intended to run essentially continuously the whole time the car is driving, so long sessions of engine cranking should not affect it.
With that smell of gas I would not park it in the garage, though.
Old Oct 23, 2010 | 09:26 PM
ryogden's Avatar
Yeah, makes sense about the pump wiring. I can't believe it would run in the condition it was in. I didn't expect to find that. I'll be sure to air the garage out a while before firing up the heat gun.
Old Nov 4, 2010 | 03:27 PM
gpatel's Avatar
Default 2006, Fuel pump 2.7 litre 6 cyl Sebring Touring
I had a fuel pump replaced at 55K - just died in trafic on day. The only thing I could think of I could have done wrong is added Fuel Line cleaner from a bottle. Maybe that burnt something in the pump. I dont know.
Anyway, dealer chaged me $1000 to change the pump!
I hear that you need to use a scan tool to de presureize the pum and clear the codes, when you install the pump, then you need to use the scasn tool to pressureize the pump. This is what I have read. Not sure if it really needs to be done using scan tools. Let me know what works.
GUS
Old Nov 5, 2010 | 09:18 PM
TNtech's Avatar
GUS
I dont know what your dealer hourly rate is but where im at that job would run you $650 tops. Shop around next time (that goes for anything) NO, you do not need a scan tool for ANY part of that job. Depressurizing is not a big deal. Just hold a couple rags around the coupling when you disconnect it. The only priming procedure is to activate the fuel pump enough to get gas up to the rail. Usually 2 or 3 key cycles and waiting a few seconds each time will accomplish that. Same procedure if you ever run out of gas.
Old Nov 8, 2010 | 06:15 AM
  #15
ryogden's Avatar
I have $110 in the pump change. If your pump was under the back seat, then that price is heavily excessive IMO. After I put the tank BACK ON after seeing the access panel, I changed it in about 15 minutes.
As far as depressurizing and pressurizing, I figure the pump going out and the car running out of gas depressurized everything. Building pressure I suppose is done when the pump finally gets fuel to the front. I did have an engine light come on along with a "gascap" show up on the odometer, but I had a line that was loose. I tightened it down and viola, the lights are off. No other issues so far.
Darth Menace
Feb 19, 2016 09:16 PM
96BTC
Sep 27, 2010 10:29 PM
Booga
Cirrus & Breeze
May 20, 2008 02:54 PM
Wonderjava
Feb 29, 2008 06:06 PM
DreWRoolZ
May 3, 2007 02:02 AM
