help with problem Please.....
Old Feb 7, 2015 | 04:05 PM
Charlie169's Avatar
Default help with problem Please.....
I have a 2000 sebring conv. i was running low on gas it started kinda chugging then check engine light came on, had codes read it said misfire on every cylinder and random misfire, egr valve, and coolant sensor any suggestions or ideas??
Old Feb 9, 2015 | 01:05 PM
Did you fill it up and see if it continued "chugging"? You are likely to get some random missing as you are running out of gas. It's also conceivable that in a 15 year-old car, you have some sediment at the bottom of the tank. That might be now clogging the fuel filter. If the problem persists, consider removing and cleaning the tank and replacing the filter that is in the tank.
Old Feb 9, 2015 | 03:25 PM
Charlie169's Avatar
yes i did fill it up and yes it is still chugging i will check and replace the fuel filter. tried some injection cleaner did not work.
mialena
Cirrus & Breeze
Apr 16, 2008 09:59 AM
wheels
Mar 24, 2008 04:58 PM
Hardcore73
Oct 23, 2007 04:39 AM
baseballchris05
May 7, 2007 09:52 AM
Boomers00
Feb 5, 2007 09:26 PM
