Need help bad please
Old Mar 20, 2012 | 10:43 PM
71dodge's Avatar
Default Need help bad please
I just bought a 96tranny Sebring vert. The cars interior has water damage not a big deal. The lady I hot it from said she had a new motor put in and it never ran right since. Wen the car is cold it runs fine. Alas soon as it warms up and you give it gas it hesitates coughs back fires and will not go down the road. But it will not stall.. I'm completely lost I've revered worked on a front wheel drive car before. I need to know how to have this problem solved. Any help is appreciated
Old Mar 20, 2012 | 10:56 PM
TNtech's Avatar
Water damage IS a big deal. What it leaves behind is a gift that keeps on giving for a Looooong time. This may not be a road you want to go down unless you have the knowledge and ability (and deep pockets) do do everything yourself including the diagnosis.
Old Mar 20, 2012 | 10:58 PM
71dodge's Avatar
It onlygot got the floors. There not rotted the car isn't rotted just the floors are filled with water. I have to gut the interior anyways to clean it all out. But I want to get it running good first
Old Mar 20, 2012 | 11:03 PM
TNtech's Avatar
What I was referring to was all of the wiring, actuator and sensors under the hood as well as lower dash, as in the junction block. You may not be sure how high the water got up inside the car, but however high it got you can pretty much be sure the outside got deeper.
I just did a Stratus that had water up to the bottom of the console but up to the the wipers on the outside. Cost about 3,000 in parts and diag to get it right (even though we strongly advised against it) but I can promise you they'll be back sometime in the next couple months with more problems. When wiring harnesses get soaked good it's a nightmare.
Old Mar 21, 2012 | 07:14 AM
71dodge's Avatar
Yea the water damage is up to the console. But all the inside still works.it only sat 7 months but I need to get it running good first
300C Ya
Nov 11, 2012 09:18 AM
solidwastetroll
Dec 5, 2010 06:40 PM
jtminnc
Oct 31, 2010 07:08 PM
keefer
Aug 5, 2010 07:33 PM
CHUNKY043
May 3, 2007 05:32 AM
