Oil leak valve cover to air box
Old Apr 3, 2022 | 09:46 AM
Tylerbraden's Avatar
Default Oil leak valve cover to air box
Hi, my girlfriend owns a 2009 Chrysler Sebring 2.7 v6 convertible. She's got an oil leak on the hose that goes from the valve cover to the air box, I thought pcv valve but turns out the pcv valve is up by the intake. I'm unsure what this hose is called or why it's leaking, maybe just needs a new hose? The oil isn't overfilled and hasn't been overfilled. There's pictures of the hose and the leak. Also her "electronic throttle control" light came on the other day then went back off when she restarted the car, I cleaned the throttle body but I thought maybe there's a common issue with a sensor or something. Have searched the web on both haven't found a good answer
Old Apr 3, 2022 | 01:18 PM
Consider checking/replacing the PCV valve. That area should be under negative pressure if the PCV valve is working properly. Then clean and/or replace the hose and see if the problem persists.
Old Apr 4, 2022 | 10:12 AM
ggoose's Avatar
If you replace the pcv valve, use oem only. Other flavors have been known to increase oil consumption.
If the hose is still pliable, consider adding a hose clamp.
Old Apr 4, 2022 | 11:01 AM
Thank you guys I thought about the hose clamp hose does feel loose but I thought it was made to go without one, I'll probably try pcv and new hose or atleast a clamp
Old Apr 4, 2022 | 11:03 AM
Anybody know what the hose is called? I couldn't find it
Old Apr 4, 2022 | 06:59 PM
ggoose's Avatar
It is called a 'make up air' hose. Part number is 4892104ab
Taronga76
Aug 14, 2018 11:43 AM
mrorange
Feb 19, 2017 02:25 PM
superman5587
Dec 21, 2013 11:08 PM
shaunneff
Jul 6, 2011 09:29 PM
mrbill
Dec 23, 2010 06:17 PM
