power steering problem, HELP!!!
Old Dec 18, 2011 | 07:52 PM
04_sebring's Avatar
Default power steering problem, HELP!!!
hey everyone, i need a little help i have a 04 sebring 2.7l sedan and my motor went bad. so i got another one from work and i took all my parts off the one motor and put them on the new motor. so i know everything was good. the problem is when i got the motor in i started the car and tried to drive it and the power steering is hard to turn, and every now and then you have a easy spot like it is working but then goes right back to being hard. any ideas on what this could be. any help would be great, thanks
Old Dec 18, 2011 | 08:11 PM
go back and take a look at your work first of all.
Old Dec 18, 2011 | 08:16 PM
04_sebring's Avatar
already did a couple of times, it has fluid, the belt is tight, i have no leaks. what else should i check
Old Dec 18, 2011 | 08:59 PM
There was a guy on here a couple of weeks ago whose harmonic balancer went bad, resulting in no charging for his alternator. I would think that if yours is failing, it might result in problems driving the power steering too. When yours is acting up, see if you can observe the belt movement. If it's jerky, that might be your problem.
Old Dec 18, 2011 | 09:51 PM
04_sebring's Avatar
i already tried that to, i had my buddy in the car while i raised it up on the lift and i watched the belt to make sure everything looked good there to and it did. belt and pulleys was working just fine nothing jerky at all
Old Dec 19, 2011 | 10:32 AM
If the pump is being turned properly by the belt there are some remaining possibilities. The pump has an internal flow control valve that is designed to relieve excessive pressure, for instance when the wheels are turned all the way to the side. That valve could have gone bad. Or you could have internal leakage in the steering gear. Or you could have a kinked hose, or a bad hose that restricts flow for some reason.
The only thing you can easily rule out is a kinked hose, which should be able to be found on visual inspection. The other things involve expensive parts with invisible problems.
Hooking the system up to a flow analyzer might narrow the source of the problem, but will involve the use of expensive equipment and a trip to either the dealer or a specialized service facility with the right gear and knowledge to use it.
Victor L
Jan 12, 2014 08:38 AM
bassy
Aug 28, 2011 12:16 PM
htran2313
Aug 20, 2011 11:43 PM
Gumby
13
Feb 19, 2008 08:59 PM
Elisha
Jan 26, 2007 06:34 PM
