Problems with brake lights
Old Jun 7, 2011 | 01:44 PM
Pookey's Avatar
Default Problems with brake lights
I found out last night that my brake lights are out IF the headlights are on. If the headlights are off, they work fine. I've checked fuses and the bulbs. Any suggestions other than a short somewhere???
Old Jun 8, 2011 | 09:10 AM
Probably a bad ground. The ground can pass enough current to operate the tail light filaments, but cannot carry enough current for both the brake light filaments and the tail light filaments. The amount of current that can pass is not enough to light up either filament. Look for a rusty ground connection, take it apart and clean it up.
Old Jun 8, 2011 | 11:43 AM
Pookey's Avatar
Thank you - I will check that out this p.m. Lets hope its that simple ~
Old Jun 11, 2011 | 08:45 AM
Pookey's Avatar
Not the ground - a mechanic friend of mine has seen problems with the light switch in the turn signal arm. `hoping for that......
darryl
Apr 13, 2015 07:21 AM
andrew143
Jun 2, 2009 06:44 AM
Josho
Oct 23, 2008 10:42 PM
Johnbush1
Feb 22, 2008 04:00 AM
