Question about front hub.
Old Nov 3, 2008 | 10:02 AM
muddauber5.7's Avatar
Default Question about front hub.
I have a 2004 sebring lx with 101,000 miles and when driving I hear a loud hum coming from frontend. As I'm driving if I turn the steering wheel slightly to the right it goes away,(as in swerving to the right)then straighten it and it comes right backI've rotated the tires with no change in sound. I'm thinking a front hub but not sure. I would apprieciate some help and what does changing a hubconsist of ?
Old Nov 4, 2008 | 11:04 PM
Default RE: Question about front hub.
There are a couple Chrysler mechanics on this site that are very helpfull. Do you have any info. for me? Thanks
Old Nov 5, 2008 | 10:20 AM
Replacing the hub is a fairly big job for a home mechanic. You will need to pull off the brake caliper and separate the lower ball joints, among other things. You might want to go out and buy a Haynes manual to get a good idea as to what's involved. Even if you decide it'sbeyond what you are willing/able to do, you will be better able to discuss the job with your mechanic.
You might consider putting the front of the car up on jack stands and running the wheels up to speed to see if you can pinpoint the noise. A mechanic's stethoscope could be very helpful if itreally is the hub bearing. You don't want to spend the time and money replacing the hub bearing if it's not the cause.
Be sure to have both front wheels off the ground and have the care solidly sitting on good jackstands (NOT the car jack) before trying this. Alternatively, you can just spin the wheel (off the ground, obviously)by hand to see if it's noisy or rough.
Old Nov 5, 2008 | 09:37 PM
Thanks for the reply dcotter, My buddy has a hydraulic lift, so we'll do as you said to see if we can pinpoint the problem area. He also has experience changing hubs if that is the problem.
Old Nov 6, 2008 | 09:27 PM
Let us know what you find. We're all learning here every day.
Old Nov 10, 2008 | 04:31 PM
irdaneel's Avatar
It can also be a half shaft noise.
pob
23
May 30, 2014 04:47 PM
mrmoleswood
Apr 28, 2012 05:42 AM
bobby719
Oct 13, 2010 02:42 PM
gareth111278
Nov 22, 2008 06:39 AM
peteats
May 2, 2006 07:20 PM
