Rear Stabilizer Bar end links, 02 convertible
Old Jun 14, 2010 | 09:08 AM
avissvcmgr's Avatar
Default Rear Stabilizer Bar end links, 02 convertible
Can anyone adivse as to how tight these should be? The book says 26 ft. lbs. but the only way I can get that reading with a torque wrench is if the nut is bottomed out on the bolt threads. Up until then the bushings just keep compressing. It seems they are way too compressed if I tighten them that far.
Old Jun 14, 2010 | 01:02 PM
That's the correct way of installing them. Do you trust your torque wrench?
Old Jun 14, 2010 | 01:28 PM
avissvcmgr's Avatar
Torque wrench is good. It just seemed that the bushings were far more compressed than they should be. The nut turned fairly easily until I reached the end of the threads and then I made sure they were torqued to specs. If that is correct then I am good. Thanks.
nickstoyz
16
Feb 7, 2015 01:15 PM
rydout
Feb 7, 2012 10:17 AM
Erbie78
Mar 16, 2011 11:24 PM
dcotter0579
Sep 28, 2010 12:20 PM
webbch
Dec 13, 2006 11:11 AM
