Rpm
Old Mar 25, 2016 | 04:09 PM
kzee's Avatar
Default Rpm
I have a 2005 sebring Tsi, and just curious as to what the RPM should be when traveling on the interstate. It is a 2.6L V6, it just seems louder than it used to be and like it needs to shift again when traveling 70-75 mph.
Old Mar 26, 2016 | 02:07 PM
I assume you meant 2.7L V-6. At freeway speeds you should expect the engine will be turning a little over 2000-2200 RPM.
Do you notice the presence of other shift points as you come up to speed? I would expect that if it's not shifting properly, the check engine light should have come on and there should be codes. You'll need a good code reader to be able to drill down to the transmission codes.
tehkoch
Sep 17, 2008 11:23 AM
davet
Dec 19, 2007 04:18 PM
snkill
Dec 9, 2007 05:25 PM
69roadrunner
Jun 29, 2007 11:44 PM
greenmachine
Mar 1, 2006 04:27 PM
