Sebring limp mode no cel
Old Aug 18, 2009 | 08:57 PM
studentmechanic's Avatar
Default Sebring limp mode no cel
1996 sebring 2.5 goes through first second than pops into neutral for a few seconds than locks into second. Speedo works fine. I replaced the input sensor and checked the 3 wire splice and ran a new ground to the tranny. I have a genysis scanner but on a 96 it does not give me to many values. No codes ever stored or any pending codes. Thinking relay and used tcm next, than possibly a solenoid pack. Any ideas or the knowhow to further check any of these components would be greatly appreciated
Old Aug 21, 2009 | 11:03 PM
Check fluid level and quality first. If you are going to throw parts at it, start with the cheapest first and replace the most expensive last. Don't start with the most expensive first. That's what the dealers do because it's good for their bottom line.
Old Aug 23, 2009 | 04:50 PM
The fluid level is perfect and the fluid does not smell burnt and is still red.
So far i started with the cheapest being the wiring, on to the input speed sensor, the relay, and lastly the tcm. None of which changed anything. The resistance of my output sensor seems to be in range and my speedo is working so that will not be replaced. My only thought left is the solenoid pack. If i could find a wiring diagram i could find the signal wire for the solenoid and see if it is getting a signal when it first trys to shift to third. That is my only idea before the solenoids get replaced.
Thanks, matt
Old Aug 23, 2009 | 09:59 PM
The solenoid pack is a lot cheaper than the TCM. Look for them on eBay and the web. I have found them for about 50 bux. It's an easy swap, done from the top after removing the air cleaner box.
Old Aug 26, 2009 | 08:43 PM
Okay i replaced the solenoid pack and it did not change anything. So i decided to drop the pan and the fluid was worse than i thought but there was not any real metal chunks in the pan just the gooey metallic particles on the magnet. So i decided to change the fluid and the filter. Same thing, still shifts one two than freewheels into neutral and locks into second. Is their a possibility of being an internal issue? I am now out of ideas, any help would be appreciated.
Thanks, matt
Old Aug 26, 2009 | 10:05 PM
Could be the overdrive clutch, which is supposed to kick in in third gear, but I don't claim to be an expert. It's probably time to get some professional help. You need special tools and specialized knowledge to get inside an automatic transmission. You've probably done all you can at this point.
xarget
May 7, 2013 08:11 AM
Heather
Sep 13, 2011 09:09 AM
flhtci
Aug 30, 2008 10:26 AM
nanu73bear
Sep 24, 2007 12:31 PM
luellajean
Aug 8, 2007 07:29 PM
