Strut tower rust
Old Jul 2, 2019 | 04:20 PM
04sebringlimited's Avatar
Default Strut tower rust
Ok.. is there anywhere I can find replacement strut towers? My passenger side is pretty rusted but not unsafe thankfully. But I'd like to fix this before it gets worse.
2004 Chrysler Sebring Coupe
Old Jul 2, 2019 | 04:32 PM
You'll only find something like that in a junkyard. You'll have to cut out the old part and weld it into place. The car is unitized construction so it's not going to be able to be bolted in. The coupe is not the same as the sedan/convertible. You might be able to get what you need from a Sebring, Dodge Stratus or Mitsubishi Eclipse coupe from 2001 through 2006. Good luck.
Old Jul 2, 2019 | 05:01 PM
That's so not the news I was hoping for lol. But I had figured as much. I just bought this car a week ago and it only has 80,000 miles. Thank you for the response tho.
Old Jul 2, 2019 | 09:08 PM
If the metal is still strong, just sandblast the rust off and paint it well. If there are weak spots, you can probably get a good body shop to weld in some reinforcements where needed.
Old Sep 21, 2020 | 12:46 PM
Adina Homrich's Avatar
Default Is it too far gone??
2004 Sebring coupe limited. Is it too far gone?
Old Sep 21, 2020 | 04:42 PM
REBEL59's Avatar
Sadly, In my opinion, YES it's too far gone.
Old Oct 9, 2020 | 01:27 PM
Jon.litman's Avatar
Yeah, that is very far gone. Even if you replace the metal on the strut tower, you should still try to find how your strut tower got rusted in the first place. You could have a leak ieak that allowed water to get in there and make the strut tower rust. Most likely it is going to be near the strut tower that is rust. Also, is your other strut tower rusted?
Old Oct 15, 2020 | 02:51 PM
Marcelvg's Avatar
in the Netherlands my car must go to a inspector every year to see if the car is safe
is this also in your country?
this rust is not happened in 1 year
Old Oct 15, 2020 | 08:46 PM
In the US, each state has different rules for inspections. Many states require no inspections, some states inspect only for faulty emissions equipment. Not sure whether "rust" is an inspection point anywhere. The car is 17 years old. In some states, cars that old are exempt from inspections figuring that if you can't afford to drive anything better than that, you aren't going to fix it if it doesn't pass inspection.
Old May 8, 2021 | 09:34 AM
toyota's Avatar
I think it is time to junk it and sell the spares. Always know when your beat or end of with a money pit.
Steven L Arthur
Dec 13, 2015 09:47 PM
amartine9823
Nov 1, 2015 02:09 PM
purplepuller
Oct 21, 2014 08:56 PM
Slammedsleeper
Jun 8, 2011 04:20 PM
ecfilms123
May 16, 2011 01:41 PM
