Think I am screwed
Old Jul 30, 2011 | 05:15 PM
speedracer1263's Avatar
Default Think I am screwed
2005 Chrysler Sebring 2.4 DOHC vin x
Had a mechanic replacing the timing belt. He was having trouble removing the crankshaft pulley. He said it was seized and never seen one this hard to remove. He tried for a couple hours and then went and rented the proper tool. He heated and applied lubricant..nothing. Then he told me the bolt broke. Offered to replace the engine real cheap for me. Is there a way to get this pulley off?
[/IMG]
Old Jul 30, 2011 | 05:54 PM
Djinn-n-Tonic's Avatar
why....??? did it break?
Nope.....If the proper tool was used on a StUCK pulley...The "FLATS" on the pulley would shear off.....From the picture they are intact...Now...with the correct tool, yes the pulley will come off...But with a Broken bolt INSIDE the crankshaft....How would you ever put a Pulley back On???
Just a question...Why is the motor out of the car??, and what do you plan on doing with the scissor Jack???
Old Jul 30, 2011 | 08:56 PM
how can u brake a bolt off inside ne way?? the dampener just slides onto the crank unless he was using the bolt for what ever reason as a point to put ahhh who knows.
Old Jul 30, 2011 | 09:07 PM
If the engine is out of the car, you might have luck taking it to a proper machine shop. They MIGHT be able to get the thing in a press and press the pulley off. Then they MIGHT be able to drill the broken bolt out of the end of the crankshaft and re-tap the hole. I doubt that many shops could do it right, and nobody will do it cheap. You might be better off taking up that guy's offer to replace the engine.
Old Aug 5, 2011 | 08:00 AM
Thanks for the response. He did not have the Chrysler tool. I got the tool on loan from auto zone and it came right off. The bolt was not broken off inside.
Old Aug 7, 2011 | 08:01 AM
TNtech's Avatar
The Chrysler tool is a POS. I use a 3 jaw I got from MAC tools like 10 years ago. Use an old 2.2L head bolt for my center. I can impact it and the threads won't damage. Used it like a couple hundred times that way and it still is in great condition.
I dont know why they can't just us the old keyway system.
Old Aug 20, 2011 | 11:36 PM
helo735's Avatar
yep you're screwed.
Old Apr 21, 2012 | 12:46 AM
Thundercraft's Avatar
Hmmmm... maybe you need a new mechanic too.
Old Apr 21, 2012 | 01:19 AM
Shadowed's Avatar
A little off topic - why cant I see the picture ? Gives me:
Shadowed, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
donnyohs
May 7, 2014 07:58 PM
rsj1957
Oct 17, 2009 05:39 PM
net1wolf
Oct 22, 2007 06:25 AM
needaauto
Feb 19, 2007 11:21 AM
Don Kael
May 26, 2005 11:43 AM
