oooops - screwed up cam timing concorde 3.2
Old Oct 17, 2009 | 05:39 PM
rsj1957's Avatar
Question Please Help - Cam timing Concorde 3.2
Thanks for taking the time to read this post.
My name is Bob and I have 2000 Concorde with a 3.2. Decided it was time to change the timing belt and water pump @ 180k miles. Also decided to replace the cam and crank seals at the same time (they were not leaking - this is an example of "don't fix what isn't broke).
When I took the cam drive sprockets off I realized they are not keyed and that the cam timing is adjusted by the loose fit between the cam shaft and sprocket (ooops I screwed up).
Now what, reading on line I realize that a tool is required to lock the cams in place to set the timing. Looks difficult as access to the back side of the cam shafts (in the head in the car) is very tight and I do not have this tool(s).
Is there an alternate method? - or where do I get the cam alignment tool? - what do I have to disassemble to access back of head to install alignment tool? anything else I should fix while its this far apart?
This posting is an example of what happens when a shade tree mechanic takes on current technology with dated experience.
Thanks for your help
Last edited by rsj1957; Oct 18, 2009 at 08:27 AM. Reason: change the title of my posting to get more people to read it
catalina0029
Dec 24, 2012 09:54 AM
speedracer1263
Apr 21, 2012 01:19 AM
rsj1957
Oct 18, 2009 04:21 PM
chum
Jun 8, 2009 08:30 PM
ymitchell
Apr 15, 2009 09:43 PM
