Transmission bolts
Old Dec 1, 2007 | 11:25 AM
ranger88den's Avatar
Default Transmission bolts
What is the size/thread pitch of the transmission pan bolts for a 2002 Chrysler Sebring 4 dr., 2.7, auto trans. I am changing fluid & filter for my neice and would like to make some line-up dowels (gasket alignment)beforehand. Also, does anyone know the recommended aftermarket ATF type (e.g. Dexron) and capacity (she doesn't have the owner's manual). Thanks for your help, Dave
Old Dec 1, 2007 | 11:48 PM
Default RE: Transmission bolts
use RTV not a gasket and use ATF +4 only
Old Dec 2, 2007 | 12:10 PM
Thank you. I would still like to use a few line-up dowels so I don't smear the silicon to badly when aligning the pan. Any idea what size? Dave
Old Dec 2, 2007 | 10:08 PM
I have been doing it for years u dont need line up pins if u get chrysler RTV it will seal up in just a few seconds. If u start monkeying around with stuff like that be preparied to fix what ever u mess up.
Old Dec 6, 2007 | 11:18 AM
Cordoba Man's Avatar
I use the gasket, but I shove 4 bolts through the corners to hold the gasket in place and hold it up and put in one corner bolt at a time and everything works out great, even laying on your back underneath.
ATF+4 is a must. Valvoline make this in a synthetic for a decent price. Tranny shifts much better... no surprises.
rhino
Jul 23, 2015 08:29 PM
mm9957
Apr 15, 2010 06:50 PM
funjon1
Jan 28, 2008 11:44 PM
funjon1
Jan 17, 2008 01:55 AM
joeuc23
Nov 1, 2007 06:35 PM
