Water leaking passenger floor board
Old Aug 21, 2022 | 02:36 PM
Mary and Thomas's Avatar
Default Water leaking passenger floor board
A picture of the whole door
Old Aug 21, 2022 | 02:40 PM
The water only appears in this area. When I opened the door, I noticed water leaking right at this spot under the passenger door seal.
Old Aug 21, 2022 | 02:42 PM
Default Thoughts on what the leak is???
Any idea what this could be?? The seal maybe?? And how would I fix??
Old Aug 21, 2022 | 02:44 PM
Default Crystler 200..year 2025 model
Thpughts
Old Aug 21, 2022 | 02:45 PM
Default Model year 2015..not 2025
Thpughts
it's a year 2015...not 2025
Old Aug 22, 2022 | 02:29 PM
It could be the door seal, especially if you have driven at speed through puddles or driving rain storms. It could also be entering from the air conditioning system. Check the door seal (weatherstripping) for its entire length and replace if necessary. A replacement should be available from your dealer or possibly from aftermarket sources such as rockauto.com or other online sources. Also check the A/C system drain. Look under the hood on the passenger side of the car for a small rubber hose that comes out of the firewall, turns down and then just ends. If you can reach it, squeeze and massage it gently with your hand. You will probably see leaves and other debris fall out as you do so. That should open up that drain and allow water to run out rather than into the interior of the car.
Drying out the carpeting once it gets wet can be a chore. If you have a wet-dry shop vac, use it to suck up as much water as you can. Then put a fan in the car and let it blow over the wet rug to dry it completely. You want it dry to the touch even when pressing with your fingers. It may take a few days to get there.
JC300
Oct 19, 2021 04:17 PM
Barbara 2
Jan 12, 2019 03:39 PM
2003sebring
Aug 10, 2015 09:38 PM
allexblake
Jul 7, 2012 04:41 PM
nirah
Oct 1, 2007 06:18 PM
