2014 300c heat/cool issue
Old Oct 17, 2019 | 09:35 AM
vakmere's Avatar
Default 2014 300c heat/cool issue
I get cool air on driver side and warm air on passenger side in heat mode. Air conditioning mode all vents work properly. Channeling thru all the modes produces the same result. NO clicking sound from under dash.
What is the problem? Something I can repair myself or get robbed at the dealership?
Old Oct 17, 2019 | 09:58 AM
mozartman's Avatar
I had the same problem with my VW Routan minivan, which is basically Chrysler Town and Country minivan.
I took it to the local auto shop. If I remember correctly they said that actuator (if this is the right term) or some kind of part that controls airflow went bad.
It cost me $180 to replace the part.
Old Oct 17, 2019 | 10:56 AM
REBEL59's Avatar
Originally Posted by vakmere
I get cool air on driver side and warm air on passenger side in heat mode. Channeling thru all the modes produces the same result. NO clicking sound from under dash.
Are you referring to when the HVAC system is operating in auto temp control and/or A/C mode? If so the A/C refrigerant charge is a little low(may have a small system leak). Conversely if you have been "topping up" the A/c refrigerant, there may be too much put into the system and this will also affect cooling efficiency.
Old Oct 17, 2019 | 03:24 PM
stylin''s Avatar
I remembered reading this on here. It might be helpful to your situation
https://www.chryslerforum.com/forum/...ows-hot-30758/
Old Oct 17, 2019 | 04:30 PM
REBEL59's Avatar
Thank you! I am getting OLD...forgot about that one, And I was a participant! One of these days I'll also remember that certain FCA vehicles were early users of the new formulation refrigerant! Too bad no follow up on the other issues with the system were addressed.
Old Oct 22, 2019 | 08:16 PM
vakmere's Avatar
There's nothing wrong with the freon charge. This appears to be an actuator issue.
Old Oct 23, 2019 | 07:34 AM
tarhealcracker's Avatar
In troubleshooting automotive problems it's well to remember the classic rules:
1. simple/obvious things first.
2. electro-mechanical things second.
3. if you have to throw parts at the problem you need competent professional help.
Old Oct 28, 2019 | 10:16 PM
calcala12's Avatar
Hi Vakmere, I would suggest for you to check with some one that has experience with r1234yf refrigerant. I Tried local shops with no resolution 5th one was a charm. That's what ended up solving my issue low refrigerant . Before I had switch both actuators on passenger side, a sunload sensor and ambient sensor with no luck. I had posted that thread in June. Now one of the new actuators went out.. my luck!
NeutronCity
Nov 8, 2019 10:07 AM
Zacr11
Dec 25, 2017 08:01 AM
fbongo
Jul 17, 2013 02:46 PM
Bobby721
Nov 19, 2008 08:21 AM
my2004
Feb 13, 2007 07:48 PM
