Cruise Control Problems
Old Mar 6, 2008 | 02:19 PM
SandJ's Avatar
Default Cruise Control Problems
Hello. The cruise control on my 2006 Chrysler 300 won't engage. It turns on but I can't use it. I couldn't find any reference in the owners manual to a fuse that might have blown. Is there a relay or something that I can check? Any advicewould be appreciated. Thanks.
Old Mar 7, 2008 | 12:28 PM
moe's Avatar
moe
Default RE: Cruise Control Problems
OPERATION
When speed control is selected by depressing the ON switch, the PCM allows a set speed to be stored in its RAM for speed control. To store a set speed, depress the SET switch while the vehicle is moving at a speed between 25 mph (40 kmh) and 100 mph (160 kmh). In order for the speed control to engage, the brakes cannot be applied, nor can the gear selector indicating the transmission is in Park or Neutral or low.The speed control can be disengaged manually by:
[ul][*]Stepping on the brake pedal[*]Depressing the OFF switch[*]Depressing the CANCEL switch. [/ul]
NOTE: Depressing the OFF switch or turning off the ignition switch will erase the set speed stored in the PCM (the ECM with a diesel engine).
For added safety, the speed control system is programmed to disengage for any of the following conditions:
[ul][*]An indication of Park or Neutral[*]A rapid increase rpm (indicates that the clutch has been disengaged)[*]Excessive engine rpm (indicates that the transmission may be in a low gear)[*]The speed signal increases at a rate of 10 mph (16 kmh) per second (indicates that the coefficient of friction between the road surface and tires is extremely low)[*]The speed signal decreases at a rate of 10 mph (16 kmh) per second (indicates that the vehicle may have decelerated at an extremely high rate) [/ul]
Once the speed control has been disengaged, depressing the RES/ACCEL switch (when speed is greater than 20 mph (32 kmh) restores the vehicle to the target speed that was stored in the PCM (the ECM with a diesel engine).
While the speed control is engaged, the driver can increase the vehicle speed by depressing the RES/ACCEL switch. The new target speed is stored in the PCM (the ECM with a diesel engine) when the RES/ACCEL is released. The PCM (the ECM with a diesel engine) also has a tap-up feature in which vehicle speed increases at a rate of approximately 1 mph for each momentary switch activation of the RES/ACCEL switch.
A tap down feature is used to decelerate without disengaging the speed control system. To decelerate from an existing recorded target speed, momentarily depress the COAST switch. For each switch activation, speed will be lowered approximately 1 mph.
bikerdude8730
Jul 5, 2013 09:10 AM
carsoftampabay
Cirrus & Breeze
Oct 26, 2012 11:31 PM
Bcurtis
Dec 22, 2010 12:40 PM
Makala
Jun 14, 2007 11:19 PM
nithawk2000
Mar 27, 2006 11:55 PM
