P0850 Error Code
Old Aug 9, 2024 | 06:20 AM
Tigerman's Avatar
Default P0850 Error Code
About a week ago my 2012 Chrysler 300 S (140k miles) wouldn’t start. No noise, no turning over, nothing! Radio and all electronics work, but no start. Replaced the battery as it was already 4 years old, didn’t help. Put a new starter in, still no difference, but the starter got pretty hot. I took it out and put it back in, not hot anymore, but still won't start. Also tried a new starter and ignition relays, didn't help.
Code P0850 says it's the Park/Neutral switch. My question is, where is that switch located and it is an easy fix? Is this the same thing as the TCM? Could there be other issues? Thank you in advance!!!
Old Aug 10, 2024 | 06:22 AM
what engine size do you have ?
Old Aug 11, 2024 | 02:58 PM
Tigerman's Avatar
3.6 flex fuel
Old Aug 11, 2024 | 03:12 PM
Tigerman's Avatar
I found what I believe to be the neutral safety switch on the drivers side of the trans. Called NAPA, AutoZone, Advanced Auto and O'Reilly's, none of them have this part. It's not out of stock, they don't carry it at all.
Neutral Switch
Old Aug 12, 2024 | 05:48 PM
Looks like a NAG transmission that would be inside the transmission on the valve body plate
Grant Metz
Aug 5, 2020 06:09 AM
Mohamed Ahmed
17
Aug 24, 2019 10:40 AM
Mitchel Brotherton
Dec 16, 2018 11:32 AM
Ever
12
Feb 15, 2018 04:58 AM
04_pacifica_4u
Feb 20, 2009 01:39 PM
