MDS indicator light
Old Mar 22, 2009 | 08:06 PM
radaham's Avatar
Question Where do i tap in for 2009 Aspen MDS indicator light
Does anyone know what is the easiest way to tap into the MDS controller wire to connect an indicator light that turns on when MDS is active? Can one of these be pick up at the coil pack? I read in another forum (for a Ram) that it can be picked up at the PCM, but on the Aspen the firewall is so far in, I don't think it's feasible. Also, If I could find out if there is a wire that is hot (12v) when in V8 mode and 0v in MDS, that would be useable also.
Thanks in advance
Radaham
Last edited by radaham; Mar 23, 2009 at 08:45 AM. Reason: title doesnt portray question needing answer
Old Mar 23, 2009 | 11:46 AM
15951a\'s Avatar
I don't have technical insight on this, but I know Aspens with the J-package indicate MDS is functioning on the overhead display when it is set to MPG. I would think it would be easier to get that feature installed than to install a light for the function.
Just my $0.02. Good luck!
Old Mar 23, 2009 | 01:55 PM
radaham's Avatar
I was told the ECO light was not available or disabled for all 2009's
Old Apr 13, 2009 | 10:36 PM
JonW's Avatar
You can create your own indicator light. You need to tap into the MDS solenoid circuit to drive the LED. I hate to steer you somewhere else, but there are wiring diagrams for doing this on a few of the LX based forums.
Old Apr 17, 2009 | 07:35 PM
radaham's Avatar
I have read the chrysler forums, and the ways to make my own indicator light, but what i want to know is "the easiest way to tap into the MDS controller wire to connect an indicator light" on the Aspen. The firewall is on the Aspen is pushed so far back that i am looking for an easier access.
WKJeepGuy24
May 3, 2021 09:41 AM
AXPTank
Feb 7, 2014 12:53 PM
09aspen
Oct 11, 2009 08:54 AM
09aspen
Jul 29, 2009 05:05 PM
sebarta
Feb 13, 2007 07:46 PM
