New 2 Me 2009 Aspen
Old Mar 27, 2019 | 11:20 AM
Huskies's Avatar
Default New 2 Me 2009 Aspen
While I'm waiting on the dealer to do the agreed upon repairs, I could use your help and recommendations. This one is not the typical "old school" Mopar I'm use to.
Where can I get a factory service manual?
What would you suggest for tires? I will need an all season leaning more toward highway than off road. I will be towing a heavy trailer from time to time.
What would you recommend for shocks? Considering I will be towing I was thinking air adjustable.
Are there hook ups for a trailer brake controller tucked away somewhere?
Also, can these thing be programed/chipped for alternate performance like towing or economy?
Thanks!
Old Mar 27, 2019 | 06:50 PM
rowekmr's Avatar
How much are you towing?
My experiences are towing a 2k Uhaul trailer with various cars prolly 5-6k loaded.
I have a 07 Aspen I believe with the tow package because I have the 4 flat and 7 round trailer light outlet on the hitch. My suspension is bouncy without trailer but the trailer settles it down but the rear sags easily. I would add air adjustable (like I had on an 00 Explorer) but I couldn't find any. If you see I had a thread for the Monroe load adjusting (towing) shocks that seem to have a secondary spring on them that I believe would help. If I don't sell mines I would install them.
58651 :: e-Catalog :: MONROEŽ SHOCKS & STRUTS
Old Mar 28, 2019 | 03:03 PM
Huskies's Avatar
8,000 max for my travel trailer.
Old Mar 29, 2019 | 07:31 AM
calamity coyote's Avatar
Where can I get a factory service manual? - To my knowledge, their isn't a "Factory" service manual other than the ones Chrysler techs probably use. Good luck getting one of those. Haynes makes one for the Durango which is the cousin for the Aspen. Closest thing available to my knowledge.
What would you suggest for tires? - I'm a fan of Michelin myself. Whatever you choose, be sure to check reviews and load ratings since you plan on towing.
What would you recommend for shocks? - Like rowekmr mentioned, Monroe load adjustable shocks have an added coil over spring which helps with heavy loads. No air adjustable shocks for our Aspen. Although you probably could add aftermarket axle air bags.
Are there hook ups for a trailer brake controller tucked away somewhere? - Yes. Located on the drivers side under the dash. Blue 4-pin connector. Should be mounted between the e-brake and wire harness block. You will need the wire harness kit to hook up to the controller. Mine was found in the rear storage compartment. Part number - 56045795AB. MSRP - $48.00
Also, can these thing be programed/chipped for alternate performance like towing or economy? - Yes. Their are several different companies that make tuners for the Aspen. Diablo makes several programmers that work well and I recommend them. I am currently using the Diablo intune I2.
Hope this helps.
Old Mar 29, 2019 | 07:59 AM
Rawyzf's Avatar
Thanks!
Welcome!
The usual suspects already posted the good info!
I am tuned with Diablo Trinity.
Old Apr 1, 2019 | 02:56 PM
Huskies's Avatar
Is there an alternate wheel/tire size for the Aspen? Mine has 20's on it now.
Old Apr 1, 2019 | 02:59 PM
Rawyzf's Avatar
I put OEM Ram Rebel wheels with 265/70/17 tires on mine. Love the look. I wouldn't go any larger on tire, unless you plan to level or lift.
Old Apr 8, 2019 | 11:29 AM
Huskies's Avatar
Looks nice. Gives it more of a truck look. I'm a little hesitant about 17s though, clearing brake and suspension parts. Problem up here in Alaska is things are harder to find locally or you pay out the nose on shipping.
Old Apr 8, 2019 | 11:33 AM
Rawyzf's Avatar
No problems clearing, and actually a lot of the Durangos came on 17s......so you shouldn't have any clearance issues.
Shipping anywhere these days is horrible......but that's the world of online shopping
Randy L
Feb 9, 2022 04:56 PM
daviddooley
Aug 27, 2021 10:47 PM
Randy L
Sep 25, 2015 10:46 AM
mrk
Oct 3, 2013 03:24 PM
bjushute
Apr 28, 2010 08:55 AM
