Newbie with an Issue
Old Feb 13, 2013 | 01:12 PM
KingZeke's Avatar
Question Newbie with an Issue
Hey gang, I am new here. I recently purchased a 2008 Limited with the Hemi. Love the vehicle. I do have a concern about some clips on the dash, right in front of the driver the dash closest to the windshield it is raising up, I can smack it down and it will stay for a while, but does that sound like clips or something else? Is it easy to access clips under that section of the dash?
Old Feb 13, 2013 | 06:08 PM
15951a\'s Avatar
It sounds like you're describing the defroster grille. It sounds like you need to remove it first to see if anything's broken (clips, etc.). To remove it:
  1. Using a trim stick C-4755 or equivalent, remove the drivers side A-pillar trim.
  2. Open the trim covers in the passenger side A-pillar grab handle and remove the bolts.
  3. Remove the right A-pillar trim panel.
  4. Using a trim stick C-4755 or equivalent, remove the instrument panel defroster grille.
Old Feb 14, 2013 | 02:34 PM
KingZeke's Avatar
I think I have the tools needed. I just don't know if I am comfortable trying to remove these pieces. I may have to suck up my fears. Just don't know enough about the vehicle yet as I haven't even had it for a week. Is this a pretty simple project? Should it take about an hour or two?
Old Mar 12, 2013 | 03:54 PM
KingZeke's Avatar
Well I did it. I took off the pillar cover on the driver's side unclipped the defrost dash. Nothing broken but the one clip was a bit loose. I adjusted it and put it all back together. It has been three days now and all is good. Thanks for the info, it helped a lot.
momin
Nov 29, 2010 08:47 AM
kyo001
Oct 11, 2010 06:42 PM
neoncrazy101
Sep 7, 2009 06:05 PM
bigw1231
Mar 12, 2009 10:01 PM
tehkoch
Sep 17, 2008 11:23 AM
