04 Cruise Control Issues
Old Jul 29, 2019 | 06:16 PM
HemiMoparGuy1981's Avatar
Default 04 Cruise Control Issues
The Cruise Control hasn't worked since we bought this car in January. I push the cruise button, and the word "cruise" shows on the dash. I push set, and "set" shows on the dash, but I let off the throttle and cruise hasn't activated. I push cruise off and the words go away, but trying to turn it back on, now the words don't illuminate on the dash...but a while later it will repeat, or after car has been shut off and restarted. I don't know where to start looking. Any help is greatly appreciated.
Thank You in Advance,,
Eric
Old Aug 3, 2019 | 06:38 PM
That Jeep Guy's Avatar
There are 3 ground wire connections on the inside of the unibody structure just below the battery tray.
One or more of these with a bad/dirty connection can cause a plethora of electrical gremlins.
If you haven't checked these recently I would strongly recommend it.
Be sure to check all of the wires going into the ring terminals, to make sure none of the wires have broken strands or heavy corrosion.
Hope that helps!
Old Aug 3, 2019 | 06:41 PM
Awesome, I'll look into this, thank you
Old Aug 3, 2019 | 06:59 PM
You're welcome!
I can't guarantee that will work, but it's definitely a cheap and somewhat easy way to fix a lot of issues.
Remember to disconnect the negative battery terminal first and I don't recommend doing this with a hot engine.
It can be reached from the top, but I found it easier to reach by taking off the left front tire and working from within the wheel well.
But that's just me. Lol
Old Aug 3, 2019 | 07:00 PM
Should be pretty easy for me, I'm an industrial electrician/engineer, I just don't have a schematic to this car so I had no idea where to start.
Old Aug 4, 2019 | 09:04 AM
djetelina's Avatar
I've got a '06 Pac wiring diagram; 446 pages and about 26 meg bytes. Should anything in particular be needed please let me know. Unfortunately experience/knowledge of the location of the known trouble spots, such as those grounds located under battery, is not included in diagram..
Old Aug 4, 2019 | 10:39 AM
I'll keep that in mind as a possibility. I know Chrysler had a lot of electrical changes right around 05-06 though, when they started using the TIPM system so it may not be much help. But if I need it and to see if it may be similar I'll let you know, thank you.
aggie78
May 4, 2016 05:58 PM
eginther
13
Nov 16, 2014 03:04 PM
TEHCUB
Apr 11, 2010 09:06 AM
cirrus98
Cirrus & Breeze
Sep 12, 2008 05:50 PM
chrisarvor
Apr 17, 2007 10:14 PM
