05 Pacifica with some issues
Old Mar 8, 2013 | 10:13 AM
ccusum21's Avatar
Default 05 Pacifica with some issues
I have an 05 Pacifica with some issues that I can use some help on. I have an AWD touring with all the bells and whistles.
1. On the NAV control buttons one of the lights went out. How do I take out the NAV control buttons to replace the light?
2. NAV module took a crap, is there a fix for it or do I have to spend the 500.00 to get it replaced?
3. How hard is it to do a tune-up on these things?
4. I had some front end work, well a lot of front end work and the car still sounds like somehting is going to fall off when hitting a slight bump in the road.
thanks, and I look forward to your response.
Old Apr 12, 2013 | 12:02 AM
lilrobert1's Avatar
Tune up is EASY I have the 05 front whl drive 3.5L found a good video on
youtube shows you how
Old Jul 3, 2013 | 06:14 PM
Stephane Parent's Avatar
For the front end noise check the sway bar bushing..pretty easy to do if you can use RAMP to roll over and get the car up...go Under and locate the sway bar.. grab it on the side where it conect with the end link and shake it forward and aft..if you here the noise ..well you found your problem..just changed mine today and got rid off the noise..
Old Jul 3, 2013 | 08:23 PM
cirrus98's Avatar
Other than being seized in rust, was there any complication?? I took a quick glance at mine and on the driver side, gaz/brake lines and the passenger side, exhaust seem to be in the way. Did you just drive it up on ramps or did you lift it and remove the tires????
Old Jul 4, 2013 | 11:43 AM
I drive it on the ramp but lifting it and removing the wheels could make it easyer.
From under the truck you can see the 4 bolts that need to be removed.. remove the metal part that hold the bushing in place and remove the bushing...reverse order for instal...good idea to lubricat the bushing with lithium grease!
It is a tight fit for the front bolts but nothing major!!
elusive416
Jul 2, 2015 10:07 AM
ricesnaps
May 29, 2014 05:03 PM
missb2004
Dec 9, 2013 10:40 PM
titanium
Dec 14, 2010 09:02 AM
Mar 23, 2006 05:00 AM
